Lobster pot - damage?
  • Thread starter Thread starter RJJ
  • Start date Start date
RJJ
14 Aug 2009
We caught lobster pot today, under sail in force 2-3. We dropped sails, I dashingly cut it free dangling off the transom and we sailed on to an anchorage.
Upon cursory inspection there is just a turn or two of rope around the shaft, no visible damage, the shaft can be rotated by hand in neutral and the prop feathers in both directions.
I will go down again with better light and a knife in the morning and cut off the remaining rope; also will check the saildrive oil again.
If all seems well, can I reasonably assume OK to engage gear? And then if so, do I need further inspection, or can we count ourselves fortunate? Or would folks urge a liftout inspection? Any other precautions recommended? Thanks.
Check nothing trapped between the prop and the anode. Line getting in there can get to the seals. Lucky escape. Time to think about fitting a stripper in case it happens again. Saildrives are £5k to replace, although insurers may pay up, still massive inconvenience.
  • Like
Reactions: RJJ
We've had lines around the prop whilst under engine sufficient to stall the engine several times. We've always been able to free of by re-starting and then engaging reverse or, where that has failed, swimming down and cutting. It's never done any harm to the saildrives or engines.
Richard
  • Like
Reactions: RJJ
You have been lucky (as have I before I fitted a cutter). However in my former professional life I have seen plenty of the dire consequences when you do run out of luck.
  • Like
Reactions: RJJ
Hows that grab yer !!
Picked up near Folly Inn on way up to Newport Quay. Thought the boat was going to shake itself to bits ... ahead - astern - nothing helped.
Photo taken once tide going out on the quay .... lot of work but care with boathook finally had it off. No I did not leave it there for another to get caught up with ...
As another says - need to make sure nothing is left that can weld to the shaft / damage the shaft exit etc. Nylon and synthetics literally 'weld' themselves over time and can be a devils job to remove.
  • Like
Reactions: RJJ
