Poey50
I see what you mean with the Victrons requiring a separate BMS so good point but the batteries do seem available to buy if I go that way.
I was thinking the Sterling was a better way to go considering both chargers are Sterling and their battery has built in BMS. I thought the main components being from the same manufacturer meant they would be matched to work in harmony but I'm guessing from what you said that's not the case ?
Yes, I hadn't meant to imply that you couldn't buy a Victron battery only that you have to buy it as part of a complete Victron system. I've edited my post as it was inadvertently misleading on that point.
Sterling really can't compete with Victron in terms of integration. Their alternator protect device is widely used in LFP systems otherwise people tend to look elsewhere for charging. Their B2B is fine because of the user profiles (where you can independently adjust absorption) but the Victron Orion is neater and, with Bluetooth, more user-friendly.
