davethedog
Hello all,
Currently sat here in Bequai and have a question for the community regarding battery discharge and charging etc .
As the weather is quite warm here the fridge and freezer (water cooled)are running a lot more than in the UK, and in the morning before the sun hits the 620w of solar panels we can have used about 130ah overnight running the inverter, movies, fans, fridge and freezer. We have a 510ah 12v gel battery bank and the ah usage and state is measured via the mastervolt shunt and easyview 5 . This also shows we can be down to 80% state of charge some mornings.
When the sun is out all day the solar will charge the batteries without issue and we get to float by about 1400 , but if it is overcast we may not get to float before evening so then we run the generator to get them there l, as well as heat water etc
Few questions;
Is 20% usage normal?
Am I being too paranoid about ensuring the gel batts are at float each day ?
Would I be better off adding extra solar (say 200w more) or switching to lithium batteries? As know the lithium batteries do not need to be fully charged all the time. Nothing wrong with the current gel batteries
Few questions;
