listless little Princess
simongoldthorpe
15 Sep 2002
Poole and Berkshire
Prinnie 315 - just had serviced theTAMD41s (200hp), all the injectors out and redone, new props (16 x 20), antifouled, all the kit taken off, Revving nicely to 3400/3500,......
BUT can only get 18knots..... why?
hlb
RIP
Any Pub Lancashire or Wales
Have you cleaned her bottom??
Haydn
hlb
RIP
Your revs might be a bit low if thats flat out. I'm guessing that a P315 is a bit smaller than my P35 So should be faster with same engines. I am not joking now. Give it a dose of Soltron before doing anything else.
Props. I cant remember now. Changed mine last year for new 4 blade. Cant say it improved anything much. I'll see if I can find out.
Haydn
Nick2
8 Nov 2002
Gerrards Cross
My Corniche with the same engines revs at about the same level but I am getting 22/23 knts without too much difficulty. However i think that this is still a bit low so will investigate prop options unless anyone has any other suggestions (other than emptying holding tank).
We should compare notes sometime as engines and set up must be similar.
Nick
<hr width=100% size=1><A target="_blank" HREF=http://arweb.co.uk/argallery/Nick2>http://arweb.co.uk/argallery/Nick2</A>
Happy1
N/A
18 Feb 2003
Europe
Try taking off 2 coffee mugs, one place setting of cutlery and a corkscrew, the boat is probably overloaded /forums/images/icons/laugh.gif
<hr width=100% size=1><font color=purple> "You only see what you recognise, and you only recognise what you know" <font color=purple>
oldgit
6 Nov 2001
Medway
Recently checked my P33 with GPS(when in possesion of 2 x trim tabs).
Gave 15 knots mean . WOT @ 3400 rpm.@ x 135 HP.
Should have thought you should be lots quicker than my heap.
<hr width=100% size=1>My little Princess/forums/images/icons/laugh.gifthe 33 of course.Shame its not just a bit bigger.
oldgit
6 Nov 2001
Medway
Re OUCH NM.
NM
hlb
RIP
Well. My boat goes much faster Upstairs than down. I got the mechanic thingy to check with his watsit thingy. He said that the clocks were reading 200 revs low. But never found out if that was upstairs or down. Suspect down stairs. So wat clocks read aint necesarily wot you get!! You Still havent sasid what size a P315. Mines 8 tons on the crane. I have been known to register 25 knots. Without trying. Othertimes 18 knots about September time and plenty of weed. Ive now started to cruise at about 18/20 knots, where as I used to cruise at 22. and about 3600 revs. Not the 3800 possible. So it's a bit of amistery. Are rev counters correct? Are diesel lines and filters full of crud. Put some Soltron in and see what the differnce is. Mine went better with less smoke.
Haydn
BrendanS
11 Jun 2002
Tesla in Space
Re: Regular use of Soltron!
>>Ive now started to cruise at about 18/20 knots, where as I used to cruise at 22. and about 3600 revs. Not the 3800 possible. So it's a bit of amistery<<
Initial burst of extra speed and no smoke. Then, kapow. Decreased performance. Obvious! /forums/images/icons/laugh.gif
Err, let me know if Depsol enters the forum, I'll go and hide.
DepSol
6 Oct 2001
Guernsey
Is that your new tag line? /forums/images/icons/smile.gif
<hr width=100% size=1>Dom
2003 is going to be a good year for me
boatone
29 Jul 2001
Just a few cables from Boulters Lock
www.tmba.org.uk
<blockquote><font size=1>In reply to:</font><hr>
Try taking off 2 coffee mugs, one place setting of cutlery and a corkscrew.....
<hr></blockquote>
Just because you havent got a bottle opener (or a fleximirrorthingy) doesnt mean you should try and make others do without............
Anyways, we're talking about real boats here, not those little traillysailly odds and sods floating(almost) plastic storage bins.........
<hr width=100% size=1><A target="_blank" HREF=http://www.boatsontheweb.com/> Website, Photo Gallery, Chat Room, Burgees</A>
trev
23 Jun 2001
London/Home Counties/Middle East
I gather your using a GPS to get the speed ? but even they can be wrong - I have a hand held garmin thingy that reads two knots higher than my (correct) fixed set. Anyway of getting a verification? cos with those 41s you should get at least 22 kts.
<hr width=100% size=1>Trev
BarryH
31 Oct 2001
Surrey
We're very tetchy this morning aren't we. Anyways, to cheer you up a bit. Pumps winding its way to Watson's as we speak in the hands of a fair maiden, well my wife.
