SiteSurfer
The thicker you go the less flexible it gets (and the possibilty of cracking it) - 2mm will bend really well but is a little fragile.
Foamex is not as good a substrate as acrylic but it easier to work with and cheaper. We used 3mm foamex to make lectern fronts that were probably a radius of 600mm, but thats pushing it a bit.
The main advantage of Foamex is its workability, you can carve it with a good knife, drill it, gently heat and bend it and I have had some good results with half cutting 90 degree external corners. And its cheap.
Do a google image search on Curved Foamex
