seaangler23
I have 2 large Inbuilt 450l diesel tanks in the boat and the original paint used to line these has failed and flaking off, plan is to clean, scrape, degrease and sand the walls (one of being the hull) then coat them with a suitable coating, the problem is most of the off the shelf coatings ive found are meant for car/bike tanks and would cost a small fortune to coat these tanks, I’ve found a polyester resin that’s meant for this but I feel it’s more meant for laying up a tank and a secondary bond with excisting glass isn’t ideal, I’d also like it to be coloured so inspection is easy and problem areas can be identified ( will only be doing one tank this year then opening it up to see how it’s faired before doing the other). The capacity of the tanks is well above what I need and I could use a bladder but either way I’d want it cleaned and painted, any ideas on a suitable coating?
