William_H
I did wonder if I should have wrapped the anchor chain a couple of turns round the bottom of the mast and dropped it into the water to give a better ground path. Would that have improved the chance of less catastrophic damage? Would that have increased or reduced the chance of a strike?
Yes I think it would reduce the damage if the boat were struck. Providing a better current path mast to water than the path mast to water via bilge, wiring, stays and wet hull. (all of which would get hot (vaporise) with current.
Re your own safety holding the tiller that is an interesting question. I think I would stay at the tiller assuming you did not have an autopilot. Certainly don't touch any metal like stern rail or backstay. Perhaps hold the tiller with something insulating like rags or plastic. The thing is that the huge current, mast to water, can produce volt drop across almost anything that current is flowing through and you need to make sure you are not part of that volt drop and an alternative current path. Have you heard the theory that you should stand on one leg while standing on earth because current flow in a strike can produce a volt drop in the earth between your feet? Is this a real way to avert harm? Is there a parallel on a boat? I dunno!
ol'will
Like Quote Reply
ol'will
Like Quote Reply
