ripvan1
Well done, but couldn't you simply have put a cover over the area the rain comes in
All done, thanks for all replys.
I used a 5 ton jack as the 2 ton wouldnt touch it.
I should have mentioned the cradle the boat sits in has 4 supports, the boats weight is all on the keel so these side supports just keep it upright, i added a few pit props as extra support.
I removed these and took the pads out of the aft supports, put the jack under the front of the keel,well padded and up she came,i had 1 x 12inch blocks that i put under the keel when a gap appeared.
In all i took the front up 6 inches, the only thing i had to be worried about was the clearance at the aft supports.
the yard guys loaned me the jack![]()
Well done, but couldn't you simply have put a cover over the area the rain comes in![]()
didnt think of that![]()
Well done, and you obviously consulted the yard before doing it, which is what I was about to suggest. At least that way they had the chance to either offer advice or do it themselves.the yard guys loaned me the jack![]()
