Grajan
After a particularly wet sail auto lifejacket brought home and hung in shed to be dried out, however when next in shed I discovered that moisture had reached the parts that other moisture hadn't reached before and life jacket had been activated. Removed spent cylinder and activation unit ready to refit replacement units after next trip to chandlery.
I was inquisitive as to what pierced the CO2 cylinder and discovered that on my XM Quickfit Auto there is a pin? that looks not unlike the top of a large needle (eye end) which is bent at an angle of about 60 degrees. Would anybody know if this is standard or have I got a damaged firing pin? my concern is that the bent pin would break off and not fire the cylinder
This is an elderly lifejacket dated -- / 01 but has been regularly checked, apart from shape of firing pin!
