nigelmercier
RIP
- Joined
- 20 Jun 2007
- Messages
- 16,234
- Location
- Live in Kent, boat in Canary Islands
Yup, I even made an adaptor.I just use an old dinghy footpump. ...
I just use an old dinghy footpump. I think when people say "dry air", they're referring to the moisture in breath which would go into the bladder if you blew the jacket up by mouth. They don't mean some kind of artificially dehumidified air supply.
Older lifejackets were susceptible to damage if left with dampness inside the bladder from oral inflation. Newer ones (as in the last ten years or more) are reportedly immune to that problem and the manufacturers say it's ok to blow them up by mouth for servicing. But even so it seems a bit unhygienic, and the footpump is easier anyway, so that's what I use.
If you have lungs you don't need a pump. From the Crewsaver website http://www.crewsaver.co.uk/Inflatable_Lifejacket_Manual/Lifejacket_Care_and_Maintenance/index.htmlThanks Pete for enlightening me, will get the Avon pump out and try it.
I did wonder about the moisture in breath inflation, and as mine is a Crewsaver of around 2001 vintage, not quite sure what their recommendations were for it?
Will in future use the foot pump, and as Nigel has done try and make an adapter for the purpose.
Philip
Moisture in exhaled air causes no problems with lifejackets which use bladder materials introduced since the Mae West went out of service.3. Check the air holding properties of the Lifejacket by inflating orally and leaving overnight. If air loss does occur, return the Lifejacket to Crewsaver for inspection.
