Life jacket cylinders on Aircraft
Thanks to Mash and Alyssa.
Seems some of the easy jet staff are not up to date.
Hopefully the web site will get updated although I wont hold my breath.
Just to confuse things a little further the Federal Aviation Authority (FAA) issue this :
http://www.faa.gov/about/office_org.../passenger_info/media/Is It Safe brochure.pdf
Note the second page
below IT'S THE LAW . . .
Do not Pack in Luggage or Carry On-board
PRESSURE CONTAINERS
C02 cartridges
Then under the PLAN AHEAD refers to exceptions (does not list) eg sporting equipment. Is a Life Jacket a bit of sporting equipment?
So what is the actual situation?
PRESSURE CONTAINERS
C02 cartridges
Your message does not give the full picture.
If you follow links from the FAA website it says, almost, the same as the CAA
Small compressed gas cartridges
(Up to 2 in life vests and 2 spares. The spares must accompany the life vests and presented as one unit) Carry on Yes checked Yes
http://www.tsa.gov/travelers/airtravel/prohibited/permitted-prohibited-items.shtm
Peter R posted the CAA master document which is a template od minimum standards that UK airlines must adopt. Howeverthe airline may adopt more restrictive rules if it wishes so you can't be certain that if the CAA master doc says OK the airline hasn't decided to apply a tighter standard. Whatever standard is adopted it must be approved by the CAA, but it is the airline and not the CAA that will tell you what rules actually apply. Sadly not all call centre staff are au fait with every tiny detail of all the regs, hence the confusion (plus in EJ's case a very badly worded website)
In reality I doubt any UK or Eu airline, or global one for that matter would ban carriage of LJ cylinders, the template is an international one that applies to all IATA carriers and few will bother to amend such trivial items as this, but do check.
If you want to carry a diving or life raft cylinder that may be a different matter.
Air south west from Plymouth to Jersey were OK last summer but insisted it was seperate to the lifejacket and in hold baggage.
Interestingly the booking staff origianlly said no, but a call to the airport and a conversation with the handling staff got an OK.
They were more excited by a knife in my HOLD luggage because the hold on the plane they used was accesible from the cabin, but eventually relented.
The key is to get approval in writing from the airline(s) on headed notepaper, getting them out of the UK is fairly easy but coming back is not so easy (bitter experience in Athens a few years ago).
security
years ago had the cylinders confiscated in dxb. no problem with the life jacket.
leaving heathrow when the hi jackers were in the frame, early eighties, just before xmas bringing kids back from boarding school to middle east. grandma had packed marzipan in silver paper for the xmas cake topping. the security were ex forces.oh christ 808 .panic
now you can ship nearly anything ,but hazardous goods are expensive.
Flew Lufthansa Heathrow to Hamburg this morning. I was bored enough to read the small print on the online boarding card. It explicitly forbids CO2 cylinders.
I'd have thought it was safer in the pressurised cabin than the hold.
A skydiver friend tells me that one sure way to attract attention from security staff is to take a parachute in your hand luggage.
Most airlines say that and this is why I started the thread to find out who had gone beyond the initial blurb and got confirmation.
Unless you are flying in a small aircraft all hold luggage is presurised the same as the cabin. Gone of the days when your luggage arrived covered in ice, unless of course the baggage handlers leave it outside for a few hours.
My personal opinion is that the hold is better with the cannister unscrewed from the jacket so if it does go off it doesn't inflate, break the zips and send your PG tips flyng around.
The cannister should never explode as such but just discharge its gas as the seal is the weakest point otherwise they wouldn't put them under your seat. Or would they?
One thing will always be true. Whatever the airline spokesman may say, there will from time to time be someone in the check-in process who thinks they know better and isn't about to be told his job by a civilian.
So true. Some check-in staff I have experienced recently have been great, others were ceratinly in training for a role in elf n safety, or a utility co call centre.
That's odd, because their website says otherwise:
http://www.lufthansa.com/mediapool/...nformation on the carriage of dangerous goods
Carbon dioxide cylinder, nonflammable, non-toxic
Description: Two small cylinders containing carbon dioxide or other
suitable gas in division 2.2 per person, fitted into a self-inflating life
jacket plus up to two spare cartridges.
Checked baggage: Yes
Cabin baggage: Yes
Approval of carrier required: Yes
Note: Net weight max. 60g and net volume max. 120ml per cylinder.
Not like the Germans not to pin things down.
