Lewmar Autopilot Drive motor
skedaddle
9 Aug 2022
I am trying to obtain a replacement motor for the above. The original is marked as manufactured by Kenlowe UK Part No KLM2189 but they no longer have stock of the 24 Volt motor. Does anybody know of a alternative motor or a vendor that may hold old stock
Thank you
Mike
skedaddle
9 Aug 2022
This is a "Pancake" style motor. Apparently this was mainly used on Kenlowe Thermo fans fitted to heavy transport vehicles. There is absolutely no way that this can be re-wound.
Alex_Blackwood
19 May 2003
Fareham
If it cannot be repaired, then take all the measurements you can of the motor dimensions including shaft length, dia. etc. fixing arrangements, voltage, wattage and amps etc. Then do an online search for a motor of that voltage /wattage/amperage. There are lots out there. Good luck🤞
PS I know you said 24 volts.
