Lenser P7 torch does not float - now need a floating equivalent replacement
tudorsailor
12 Jun 2005
London
zebahdy.blogspot.co.uk
I loved my Lenser P7 torch. Unbelievably bright light in a little torch. Have had it for maybe 5 years? On way back from dinner in dinghy I proved that the torch does not float and is water resistant but not waterproof. I watched as it stayed on while sinking into 10m of water.
I would like another but maybe should get something that will float if/when dropped into the sea.
What is the best small floating LED torch???
TudorSailor
It's a great torch: I keep one at home.
Have one of these Lenser P14 torches on board: at least it's waterproof and I can use it under the prop.
http://www.ebay.co.uk/itm/LED-Lenser-D14-Frogman-Diving-torch-150-Lumens-/151230793395?pt=UK_SportsLeisure_Camping_LightsLanternsTorches&var=&hash=item23360ec6b3
As for floating, I wouldn't expect any torch to float (without being really bulky), so I'd either tighten the adjustable strap round my wrist when using it over the side, or possibly attach it to one of those big inflatable balloon buoys if the problem is dropping it overboard rather than letting go when you're swimming with it.
Check out the Afunta torch - it is so cheap and brighter than the LED Lenser. Get a similar quality dive watch and have a float attached to it!
I loved the LED lenser until I bought an Afunta (for fun) it was way brighter and although I thought it would break the first time I dropped it, well it didn't have I now chuck it around demonstrating to people "look it still works £7.99 Bargain (found cheaper if you look harder)
Decent torches won't float, batteries are heavy. Just use a lanyard.
I've got a Nightsearcher Trio Rechargeable LED Handlamp, it's awesome:
Black: http://amzn.to/1o1cIZ5
Yellow: http://amzn.to/1DgnynO
Or of course there are a number of small pocket types for a couple of quid:
http://www.ybw.com/forums/showthrea...torch-%A33-42-delivered&p=4674551#post4674551
Awful compared to the P7 for
The same money, sorry. The cheap afunta style are at least shook proof and can fit in a pocket but are 300lms where as the black
And yellow are much less and 10x+ more expensive.
I had something similar years ago and I would to go near those for that money these days. £50 on a torch that doesn't have 'shock proof and waterproof' on it is borderline a rip off.
Apologies but they are far too bulky for a dinghy bag
I bought a Lenser P7 from a previous thread recommendation several years ago. I have used it for my everyday work ever since and have recommended it to many others. There is no other option, get another and attach it to yourself whilst in the dinghy.
I suppose you could wrap the Lenser in some pipe insulation. The button is at the end, and th einsulation would mak eit
a) float
b) protect against dropping
c) less likely to be nicked
d) not so cold to handle
The reason the better torches are aluminium is for heat disipation.
I would be concerned about overheating with this solution.
The Lenser range is not waterproof and as such is not a great choice for boats. There are plenty of fully waterproof options.
I'm not aware of floating torches that would match the P7 for size, brightness and quality. You might want to look at Klarus e.g. the XT10, they are similar in quality and price to Lenser but waterproof, at least. (I have the XT11 - bit brighter - and it is excellent!). To make it recoverable, I would attach a small auto-inflating keyring or, if you use it under water, a lanyard as suggested.
Alternatively, you can get a similarly bright, surprisingly good quality yet very cheap Ultrafire e.g. WF-501B with 5-mode switch. They are around £5-7 on Amazon and waterproof. Having tried 10+ alternatives, this is the best "cheap" model in my view. I keep my expensive torches at home but leave a couple of Ultrafires (CR123 and AAA versions) scattered around the boat, garage, in every toolbox, etc.
