Lenco vs Bennetts
Neither - I've got Twin Disc on my boat.
Nowhere near as popular as Lenco and Bennett, but they make even their best products look like toys, in comparison.
Not cheap, but for any "normal" P boats (bar smallish ones), you could do worse than fitting them.
Otoh, for speedboats well above 50kts, Mercury K-planes are just the ticket.
Lenco electric or Bennett’s hydraulic trim tabs?? What you got and what are the views for and against each ??
I was just googling Lenco trim tab problems..........
I had problems with a cracked actuator on Bennett in the past but the replacement was very easy to fit and provided free of charge despite them being very old.
The lenco have packed up after 6 years. The advantage of them is they auto retract when you turn the engine off and they have indicators. Maybe some Bennetts have this too?
To me it just seems silly to keep an electric motor underwater.
I have Lenco.
I did consider upgrading to Bennett but the cost was so high, that it was cheaper to buy lots of Lenco actuators and fit them as required.
Tip - if you buy the Bennett to Lenco conversion kit, you get two actuators for the price of 1.
I usually buy from the USA and wait for the delivery.
Actually, this post reminds me that I need to add a couple more to my stock.
I have used this replacement strategy over the last 12 years and I am well "in pocket" over a Bennett upgrade.
I have Lenco.
Crikey sounds like I’ve done well with getting 6 years. How many have you been through?
Yep, Twin Disc for me too and they are pretty substantial. Their UK support is good too via their key distributor, was easy to locate a seal kit when needed.
Got Bennett trim tabs on my boat, they've been bullet proof reliable for the last 14 years. The only issue I've had was this summer where one of the dashboard switches failed, I bought a new switch panel from the local chandlery and fitted it myself.
They haven't needed any maintenance either, no new seals required. I'm amazed they've done as well as they have.
Parker 7.5mtr cabin cruiser c/w 300 outboard – When its ruff zipwake on automatic keep the boat completely level so you can concentrate on driving.
Bennetts we had were on a 11mtr cabin RIB with twin 315hp inboards diesels.
By level, do you mean that they are effective in correcting any LISTING due to crosswind and/or unbalanced load (both of which can badly affect how level the ride is, in a 7.5m boat), or that you can see a relevant reduction of ROLLING?
These are two very different things, the latter being the one I am a bit more skeptical about.
But if you say that they are effective also in this respect, I have no contrary experience, and I'm happy to take your word for it!
Next question would be about whether such effectiveness is equally remarkable on larger boats - if anyone knows, I'm all ears.
Not an answer to the OP but I can definitely NOT recommend the QL trim tabs by volvo. I had a new installation on a boat 5 years ago and had three replacement blades and one controller within 2 years.
