fisherman
In a campervan, which I bought so no knowledge of wiring detail. It has a solar panel, MPPT controller, and something that clicks regularly down near the start battery when the sun is out.
On hols, with only the waeco fridge on, the battery would be dead an hour after the sun went. The fridge would start up in the morning with even minimal light on the panel. Avon 631, can't find if it's deep cycle or not, I disconnected it and after 24 hours it shows 13.2 volts.
I threw a sheet over the panel, turned everything on, the fridge draws 6A as described on the spec, without it there is a 0.3A drain. Where's my leccy going? The panel will handle the fridge and a peltier cold box at 48w no problem.
