lustyd
I saved £10/month in shore power when i switched from lead to lithium simply by no longer trickle charging.I have always found if you keep batteries trickle charged they seem to go on forever
All boats behave better with more ballast in rough weather. In the Fasnet disaster the boats that became semi flooded became more stable. Many skippers reported this fact.That depends very much on the boat and does not apply to all boats
My boat weighs 19 tonnes loaded. The fuel, water and holding tanks are under the floor with a total weight of 1.3 tonnes. The batteries are higher than the tankage, located under the saloon seats. My 90kg of lithium or 230kg of lead batteries won't make any difference. There is 6 tonnes of lead in the keel with a draft of 2.2mAll boats behave better with more ballast in rough weather. In the Fasnet disaster the boats that became semi flooded became more stable. Many skippers reported this fact.
The Mary Rose quite famously didn’t.All boats behave better with more ballast in rough weather.
Wow! Your a geniusHaven't ever seen a yacht yet with a plimsol line and I know what happens to a yacht when their ballast drops off. (Keel)
Perhaps in your case you have enough but in the general rule of thumb the more ballast the more stable, that is why all ships can take on water ballast into huge storage tanks to make them more stable and I think even the smallest coaster is more than 19 tons. You say you are 19 tons but how much of that would be below the water line because your keel is less than a third of the weight of your boat which is not necessary a good ratio.My boat weighs 19 tonnes loaded. The fuel, water and holding tanks are under the floor with a total weight of 1.3 tonnes. The batteries are higher than the tankage, located under the saloon seats. My 90kg of lithium or 230kg of lead batteries won't make any difference. There is 6 tonnes of lead in the keel with a draft of 2.2m
Ballast ratios are not quoted by manufacturers for boats loaded up with all the cruising gear they could carry. The theoretical weigh of my boat, presumably empty, is 14.5t.Perhaps in your case you have enough but in the general rule of thumb the more ballast the more stable, that is why all ships can take on water ballast into huge storage tanks to make them more stable and I think even the smallest coaster is more than 19 tons. You say you are 19 tons but how much of that would be below the water line because your keel is less than a third of the weight of your boat which is not necessary a good ratio.
Thr manufacturers literature from 1980 says 14.5t. Reality when loaded is somewhat more. It's not hardOne minute your boat is 19 tons the next it is 14.5 tons. I withdraw from this discussion. There is a saying about moving goal posts. Cheers
They just sail higher in the water and go a bit wobbly but not a huge issue. The instructor sailing on the Cornish Cruising boat without a keel took several days to even notice.I know what happens to a yacht when their ballast drops off. (Keel)
