coopec
N/A
Maybe I should go for netting rather than cloth (canvas)
https://www.safetynetsaustralia.com.au/files/SafetyNetsBrochure2017_June.pdf
What about lee cloths on the "V" berths? Would "Y " shaped lee cloths be OK?
Remember someone has to be sailing the boat, so not all the bunks will be in use under way. Quite likely whoever sleeps in the forepeak in port or at anchor, will doss down in the saloon instead when on passage, for a more comfortable motion.
Ah yes, good point. Luckily I have a narrow cabin too, so little room to get up speed.I assumed he was thinking more of someone standing in the saloon falling against the leecloth. The same reason saloon tables need to be very strong against sideways shoving.
I think this is an important point. When the boat is heeling, it lets you adjust the mattress so that the sleeper is more level and comfortable as well.I think it is important that the underside of the lee cloth extends at least to the center line of the berth. In use, the lee cloth will curl the mattress and help hold the occupant securely across their hips and shoulders. They will be as one with the boat and not be rolled backwards and forwards like a bit of pastry.
