LED interior lighting (again)
BlueChip
24 Aug 2004
Bucks/Plymouth
My Westerly had halogen down-lights that I converted using the circular multi LED panel bulbs several years ago, power consumption is minimal but the light isn't quite as bright as the old halogens were and does seem to have tailed off as they age.
Earlier this year I bought a couple of replacement 3W down-lighters on eBay, that fit into the headlining plinths fitted on my Westerly as an experiment.
The light is amazing to say the least and the lights even swivel so the beam can be adjusted.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=350680741926&ssPageName=ADME:L:OC:GB:3160
I have now ordered some even 9W lamps of a similar design, non swivelling but much brighter and with a frosted diffuser-
http://www.ebay.com/itm/9W-3-3W-LED...C-85V-265V-Warm-Cool-White-New-/350888353825?
They have just arrived and I'm very pleased with them, but from first look I think they might be too bright.
I will probably mix and match them so I can turn them on selectively as required.
demonboy
11 Oct 2004
Indonesia
www.youtube.com
This is a very good find, and coincides with my search for something similar. My problem is the 50mm depth, I only have certain areas where I could accomodate something that deep, but these are a good find, thank you.
BlueChip
24 Aug 2004
Bucks/Plymouth
Westerly overcame this problem by mounting the original fitting in a circular wooden plinth covered in headlining material, this gave enough depth for the fitting and looked quite good.
Ric
8 Dec 2003
That's just what I'm looking for too - sorry I started a duplicate thread before I found these.
What size hole do they fit into? I can't find a measurement on those links.
