A1Sailor
Antifouling isn't imperveous to water - the hull can dry out through it. If it were imperveous, there would be no need for "Gelshield" type epoxy coatings.
So there's no hope for the countless thousands of boats which are afloat year round?
Polar Maritime, Arctic Maritime air masses are not "dry', only Polar Continental is dry. See Metoffice Learning: -
https://www.metoffice.gov.uk/learning/atmosphere/air-masses/types
Tony Staton-Bevan in Osmosis & Glass Fibre Yacht Construction (1995) says: "If at all possible, the vessel should be stored ashore when not in use. The benefits are two-fold, the hull will not be absorbing water during this period and it may even partially dry out. It is no coincidence that those craft left afloat for 12 months every year, develop blisters much earlier." (p108)
Many of us who sail and look after elderly yachts built before the change to better resins may do well do heed his advice?
I am not at all confident about a document that was written quarter of a century ago. We have a lot more experience of the material and to this day we don't see any boats sinking due to "soggy hulls".Tony Staton-Bevan in Osmosis & Glass Fibre Yacht Construction (1995) says: "If at all possible, the vessel should be stored ashore when not in use. The benefits are two-fold, the hull will not be absorbing water during this period and it may even partially dry out. It is no coincidence that those craft left afloat for 12 months every year, develop blisters much earlier." (p108)
Several illuminating reports. Thank you.
Rightly or wrongly, this morning I agreed with the Ullapool boatyard to take Khamsin out of the water in the next four/six weeks. She'll stay ashore, hull un-covered, until springtime.
The local boatyard chap won't be ready until next season - and when I told him my mooring just along the shore from his slipway had not been serviced since new in 2010 he agreed I was doing the right thing by not risking leaving her in the water.
Sorted :encouragement:
But keep the Post and dialogue going, I'm fascinated and may even be learning something![]()
Perhaps you could buy some snow shoes and walk out to her on her mooring.He told Express.co.uk: “November is looking like a mixed bag of weather this year and there are signs that amidst stormy weather will be the first proper snowfall, temperatures for the month are expected to possibly be below average.
“All our long range projections have been showing for quite some time that December is likely to be a colder than average month overall and we are expecting several widespread snowy periods early in the month.
“The period between Christmas and New Year is looking interesting as there are likely to be some major low-pressure storm systems hitting the UK and these will clash with much colder air over the country bringing potentially crippling snowfalls and ice storms.
“This year we are expecting potentially hazardous winter conditions from early on in the season.”
https://www.express.co.uk/news/weat...e-forecast-uk-winter-2018-snow-radar-November
Well she's still in the water. Might you change you mind and do some winter sailing?
Perhaps you could buy some snow shoes and walk out to her on her mooring.![]()
Prior to buying my current boat, launched 1986, it had been ashore for 15 months and the moisture readings were "in the usual range for a boat of that age", to paraphrase the surveyor. Now Devon is not the driest county but clearly the 15 months ashore, in this case, made no significant change.
At my age I am pretty sure the boat will outlast me, just hope there is some way that I can dispose of her in an environmental way.
You can research on line why this advise is both old school thinking and possibly wrong, especially on older GRP formulations and construction methods. Water molecules that move through GRP do so because they are small enough to move through (the hull does not absorb water). As they pass through the GRP they can come in contact with other chemicals and may react such that the new compounds have bigger molecules that will not travel through the composite. The only way to get the bigger molecules out is to peal the GRP off and use natural ventilation or more efficiently use a Hot Vac system.
It has been established that you can take a new boat, measure the moisture reading before she has ever seen water, launch her and at the end of the season, maybe even less time than that, when you take her out the water, immediately perform a moisture survey and it is very likely that she will show elevated moisture readings. A week or so later, if repeated, more or less independently of the atmospheric conditions, the moisture levels will have reduced back to the new state, or very close.
On older boats that have old resin formulations and old manufacturing methods the GRP can have dry glass fibres (wicking), air bubbles, uncured resin, bonded in materials for GRP stringers (foam, wood, rope), fairing foam covered in GRP at skegs, encapsulated keels, shaft tunnels, bonded in ply. All these materials or defects can trap moisture such that it will not easily be removed again.
There is also an opinion that the cooling effect of water, or even molecules of water moving through the GRP, slows down the reaction that is happening to cause osmosis - refer to this book http://www.osmosisinfo.com/osmosis book.html and as such the boat should be left in the water. The logic with this statement is that the transfer of water molecules happens from day 1 and if a reaction is going to happen it starts in day 1.
As a buyer of an old boat and now owner, I looked into this in quite some depth. There is even a belief from chemists that all our GRP boats, even todays GRP boats, will simply break apart over some long period of time as the resins are not stable compounds and will inevitably break down (they just appear stable in our time frames).
Drying out is not a reason to lift out every year, the water molecules have already started the damage and lifting out will not stop it from happening, which is the conclusion I have come to. There are other reasons of course to lift out annually, especially on older boats that require a lot of TLC to maintain.
It's never straight forward advice, we all can find sources to back up our experiences or shore up our knowledge. The books that talk about the chemistry and physics involved in osmosis I tend to believe. Maybe I am wrong.
Thanks for the link doug, an interesting read.This is lately revised and worth inspection:
https://r.search.yahoo.com/_ylt=Awr...s3v6.pdf/RK=2/RS=z.YPuXpriX59x_HXL3qtYN.i2ng-
My moorings haven't been checked since laid in 2010, but everyone reckons they are so heavy and over-engineered they won't be a risk. (I'll be replacing the warps (two) this autumn anyway.
The 'IMPENDING CATASTROPHE' light is flashing in the corner of my screen.
I had a boat break it's 3 year old chain mooring in a force 6 a few years ago. Some good chaps from the club rescued it within minutes so I only needed to replace rigging, not the boat.
Please, Please, Please check that mooring chain and sinker. I've seen pin-thin worn 10mm chain. 12mm thick wire hoops broken at the top of 2 tonne sinkers. Knackered swivels work through with sand carried by the tide in a couple of years. For the sake of your being able to sleep on a bad winter's night, make sure your mooring is good, even if you have to pay someone to lift it and carry out the maintenance yourself.
I one hundred per cent agree with you. A big part of my decision to have Khamsin ashore this winter is just what you say. Annoyingly there are very few mooring people up here and they all seem to have no time to check my mooring(s), even though I have told them I'll pay.
I hope to have found another moorings guy, but he's proving difficult to track down.
I hope my insurers don't monitor YBW posts...……………………………..
Thanks for your concern.
