yodave
Thanks to each of you for your replies:
prv: I'm unsure how the rotation happened, although on our last trip there were two loud noises that sounded like a slipping fan belt. With hindsight we reckon that those noises must have been the tube rubbing on the shaft (you can see the worn tube in picture 2 above). Can't comment on the lugs, as I haven't seen inside. Sounds like I might have to consider dismantling the component parts for a look. Before I do that however, I think I'm going to make further enquiries to see if I can identify the make and model of gland ...and access technical info.
Tranona: The clamps were loosened and tightened again on Thursday as part of the process to find a short-term fix. I should now double-check that these are tight and don't just appear to be tight (given your experience). It sounds as though these clamps being loose may well have been part of the problem - allowing the rotation to happen. That said, I have to keep exploring the root cause of the problem to ensure that I cover off all the bases.
ianat182: Unfortunately I'm not mechanically minded. As such I don't know how my stern gland works ...and if I'm totally honest I haven't managed to get my head round your observation about the seal being squeezed at one end and protuding at the other. So I'll have to do some further work on this in order to take on board your comment. I agree that I don't think there is an outlet pipe for the water ...and at this stage I'm unsure where the water is supposed to go (although some of it at least appears to be going into the bilge in the form of my unwanted drip).
Thanks again to each of you for your input! : )
