Andrew_B
I have just taken the waterpump off my Yanmar 3GM as it has started to leak from one of the small holes just behind the pulley.
I've taken off the pulley which reveals a bearing held in by a circlip.I have also taken out the impeller.
If I remove the circlip will the shaft and bearing simply knock out or is it a job for the Yanmar man.
Also if it does knock out is it usually bearing failure that causes these pumps to leak or is there some kind of seal inbetween the impeller housing and bearing which wears.
Any help would be much appreciated as I am now stuck to the dock.
Andrew
Andrew
