Leaking seacock - should I worry?
Otter
23 Nov 2004
Norfolk
I went to turn off the loo inlet seacock today and it was obviously leaking - a steady drip every few seconds. It's a Blakes seacock and I tightened up the two side bolts that sort of hold it together. That appeared to stop the drip, I dried it with a bit of tissue and no new drips. Have I cured it or is this indicative of a real problem?
We changed over to summer haul out this year and so we're not due out for another 9 months so I need to find out if we need a haul and check.
Thanks.
Thanks.
They are a tapered valve, by tightening the two nuts you have pushed the tapers together and fixed the leak. That is normal
S
Thanks.
Job done Kipper
What Skipper-Stu said is right,and when you get the opportunity remove the rotating bit and add some grease to the mating surfaces. This allows it to turn nicely without leaking or sticking. Good kit they are and should last a very long time.
I used to remove the one on our previous boat every winter for a clean and grease. I think that every 3-4 years I degreased the parts and assembled with a little fine grinding paste. Just a matter or moving it around and to-fro for a couple of minutes before taking it apart to clean with solvent and re-grease. Seemed to work and still perfect after 30 years in use. I don't imagine that yours will be ready for the bin for many years unless it has turned pink with loss of zinc (unlikely unless you spend a lot of time on a poor shorepower connection).
Ensure that you can still turn the seacock after tightening the yoke bolts. These plug valves can seize very readily and need to be exercised occasionally in any case. Once they have seized it can take some heavy blows on a drift from outside the boat to free them.
Thanks everyone, reassured now, it was worrying leaving the boat yesterday.
Vyv is so right - we were new to this type of valve when we first bought the Kipper and thought we should tighten it as hard as we could - socket set and everything. It took the guy at the yard half an hour with a drift to free it :o
The blakes grease is available in the swindlery, i took out a mortgage & purchased a pot for my MaxProp
I was thinking this would be done when out of the water with them removed. Bonus if you could do in situ.
Yes, but the boat would need to be out of the water, with the plug removed, and you would need space to drill and tap the body (which with the location of 3 of the seacocks on my boat, you don't have).
