arto
I'm collecting roughly a bucketful of water a day in the bilges of my boat and the saildrive looks like the culprit by a process of elimination.
Could water be finding its way around the seal *without* it being obvious from a visual inspection of the saildrive? Viewed from above (i.e. from inside the boat) the seal looks to be intact and there's no obvious ingres of water.
The boat is a 2001 Dehler 36 with a Volvo 2030 and saildrive. There are relatively few potential leak sites below the waterline when the boat is at rest.
The four seacocks for the heads and galley all seem completely dry.
There is no leak from the log impellor.
I've drained and dried the bilges completely and can see a trickle appearing from the aft part of the boat - i.e. not from the keel bolts - but because of the inner moulding I can only be confident it's coming from somewhere aft.
That leaves the saildrive and the rudder. It's not the rudder which is at the extreme aft (and the bilges are dry between the rudder and the engine).
That leaves the saildrive. This looks completely dry from above. What I can't figure out is whether there could be any ingres of water that I can't see - and never having inspected the hull with the saildrive removed, I'm not sure how the whole thing fits together.
Failed saildrive seals seem to be pretty well unheard of, but are presumably possible or Volvo wouldn't recommend their replacement every 7 years. The saildrive was removed to gain access to the engine a couple of years ago and I guess it is possible that the seal was damaged or some dirt introduced at the time.
Any thoughts? My current plan is to have the boat lifted and to replace the saildrive seal but it's not a cheap exercise and the thought that I could be chasing a wild goose pains me.
