mireland
I have a Johnson raw water pump on a Bukh 36 that is freshwater cooled. The raw water pump has been leaking as evidenced by rust all over the place beneath the pump! I checked it out while the engine was running today and found that no water was coming from the cover but instead appeared to be coming from the space between the impeller housing and the body of the the pump. It is the bit where you can see a shaft turning!
Can I repair this myself and if so does anyone have any simple advice on what I need and how to go about it. Have looked in the manual but it is not very clear to me.
Many thanks in advance
