lumphammer
The pump on my Lavac has an electric drive on a Henderson Mk V body. I can't stop water getting into the drive side of the diaphram (leaking out of the bdrain hole in the motor drive).
I have stripped down the diaphram and it is in good condition, I can't see an signs of wear or holes. I assume water is getting between the washers and out via the screw hole.
Can someone confirm which way round the washers should go, and can I use any sealant around the central fixing bolt?
TIA
TIA
