Int14
New Member
Sea water is getting into the fresh water circuit, causing the filler cap to vent and lots of coolent in the bilge. The cause is the domed rubber cap, which connects the sea water cooling hose to the heat exchanger, is failing to seal, on the smaller diameter part that seals on the sea water cooling tube. The jubilee clip is failing to do its job, as there is not enough of the heat exchanger to tighten up against. The clip then twists off as it is tightened. I think the jubilee clip is also tending to slacken as the engine runs.
As this is such a common engine, I assume there is a solution to this. The high torque jubilee type clips are wider, which makes then unusable. Is there a better clip which is narrower than a standard jubilee for a 70mm diameter application?
Is there a sealant or other solution to "lock" the jubilee clip onto the rubber cap so it won't slip off?
Any other ways of solving the problem?
many thanks
many thanks
