leaking gm 10 waterpump
vfrbiker905
New Member
31 Jul 2006
I am sure some one here will have had this problem
my water pump is leaking, on inspection using a
mirror it is leaking from the pump body
in other searches I have discovered this leak is
probably the water seal on the shaft
main question is can this be repaired or am I
at the hands of yanmar extortionists an need to buy a complete
pump
thanks
george
pump
thanks
george
diy fix
When I owned one of these, the shaft in the pump needed replacing. It was about 70 pounds - probably rather more now.
pump
thanks
george
pump
thanks
george[
/QUOTE]
See the GM-HM workshop manual at http://www.motoren.ath.cx/ for instructions.
I had this problem last season. The water lip seal on the shaft can wear the shaft leading to a leak. I removed the pump and disassembled the seals and bearings, and polished the shaft to remove the ridge [using fine wet and dry, with the shaft in the chuck of a drill press]. Reassembly with new seals solved the problem.
If the ridge can't be polished out, then a new shaft is needed, either from a Yanmar spares supplier or a friendly machine shop.
There's a very good post on doing this:-
http://www.ybw.com/forums/showthread.php?252377-Replace-Yanmar-1GM10-water-pump-seals-repost
