Akestor
Hello!
The front SS water tank started to leak...It's a Westerly Longbow 31, and the tank is installed under the V-birth, the only option for removing it is surgery on the fiberglass and then rebuilding it... It's frustrating to have to begin a massive job only to repair a small leak...
I suppose the leak is on a seam and since the tank is 50 years old might not be worth it to repair it and get a new leak in another spot sooner or later.
So I'll need to build a custom plywood tank or at least insert a flexible water tank in there which obviously is not optimal for capacity but an easier solution
Would like to hear from the people who did this and what solution was found for their new tank.
