stephen_warby
I can't tell how happy I am to find this forum!
I've read PBO fro that last ten years or more and could never get enough and I now I can actually ask questions!
My question this time concerns the Deep Sea Seal (rubber boots with bronzy ring sort of surface to surface seal) on my propellor shaft. It was new and after 3 years with the boat ashore for refit it has leaked for the last 3 years when the engine is running. My boat is steel so I really don't want a leak. I contacted the manufacturers and they werehelpful but not sure. I have checked that it is evenly aligned, pushed the two boots closer together but the seal still leaks after all this time. The boat is coming out of the water in 8 weeks and I want to get it working if possible. It has been sugested to me that there is grit caught in the seal or that I should grind the surfaces down a bit with wet and dry paper over a peice of glass but that could make it worse. Does anyone have experience of this sort of problem and maybe a solution?
Thanks Stephen
Thanks Stephen
