petibonvm
hello, on my SO35 my water heater (220v + motor) has a small leak (one glass per day). If I put a cap on the cold water inlet and hot water outlet and drain, is there a risk of engine overheating? Thanks for your help
It should not affect the engine temperature as it is only the same as when the tank is hot and no longer takes any heat from the engine.hello, on my SO35 my water heater (220v + motor) has a small leak (one glass per day). If I put a cap on the cold water inlet and hot water outlet and drain, is there a risk of engine overheating? Thanks for your help
