hans
We have an aluminium sailing boat (Koopmans 39) built in the Netherlands 1995 – 1996. Last year we discovered a faulty weld in the bottom of the keel, water slowly dripping from the keel when hauled. The boat has spent the winter in a shed for some major surgery to the keel. On pressure testing the keel we discovered 3 faulty welds in the bilge area. Apparently this is not that uncommon in older aluminium boats and is by some felt as the main reason for our keel problems, with water leaking into the keel from the bilge.
We found some very useful information about this on this thread on a Canadian website:
http://www.morganscloud.com/2012/07/01/one-tough-old-aluminum-boat/
The keel section is filled with lead. We have no details about how this is placed in the keel. We have now made access holes to the keel so we can see top of what we believe is the lead, but cannot really see whether the lead is moulded in place or set as ingots in epoxy. Ultrasound measurement of the keel shows no areas with less than 6 mm (the plate thickness), although this is of course no guarantee against there being pin-hole electrolysis. None is visible from outside, and bottom 1' of keel was sand blasted before the repairs.
We have spent a lot of effort in repairing the keel and searching out and repairing the leaks in the bilge area. We plan to treat the bilge with epoxy. Although the keel now is presumably dry after several weeks of vacuum applied, there is bound to be some salt in the voids between aluminium and lead. The combination of aluminium, lead and salt water should constitute a potent battery, and we are told we should fill the keel cavity with oil to neutralize this effect. I understand this will make later welding repairs difficult, but our welder states that with the new access holes any oil can later be rinsed out before any further welding.
My question to the forum is this:
Does anyone have any suggestion on what kind of oil would be best to use for this purpose? Some suggest vegetable oil, some suggest diesel, some old engine oil, or could we use anti-freeze made for aluminum engines? The oil/liquid needs to be thin to creep into the presumably small voids. Epoxy does not seem to be an option as there is no way to prep the surface for adhesion.
Any thoughts/suggestions much appreciated!
