Quandary
My neighbour has a problem with the lead roof of his bay window. There is a secret gutter which is made up of sections of lead with soldered joints. One of the joints has parted and rain is running down inside the window frame. Apparently modern plumbers no longer do lead work and roofers are not too good at some of it. It seems to me that resoldering the joint should not be that difficult, anyone got any advice on preparation, dealing with the weathered edges of the crack, type of solder and flux to use?
We have been discussing the possibility of also lining the gutter with GRP, this would not seem too difficult but it would be critical to get a permanent bond between the GRP and the lead downstand as if water gets between it would be a serious leak problem. I don't want to advise cutting the lead to form a flashing though this might be possible. Having recently worked on my lead keel where, on tackling a chip, the manufacturers epoxy paint coating on one side came away in sheets with no effort, I wondered if this was just poor preparation/degreasing or is lead resistant to adhesion? I have since cleaned the keel with acetone and overcoated with coats of West epoxy with fillers to thicken it and short of destructive testing it seems to be adhering OK. Lots of recent flat or low pitch roofs around here are coated with polyester resin on mat with a grey flowcoat that looks like lead from a distance, would epoxy give better adhesion? Will weathered lead with its oxydised surface give a good key or would it be better to abrade to a bright surface?
Any technical advice would be welcome as I have promised to tackle it on the next dry day which could happen anytime in the next few months.
