[2574]
Lead acid batteries have different charging requirements to Gel/AGM batteries. As I understand it the latter require a lower voltage charge as compared to the former. Does anyone know of a fancy alternator regulator which would enable a single alternator to charge the different battery types with the required correct (different) voltages? If not a regulator how else can this be achieved? Or should one never mix lead acid and Gel in the same system. I've heard that the whole system voltage should be reduced to suit the AGM/Gels - but that would mean that the lead acid's would never be fully charged?
Any thoughts would be appreciated.
rob
(ps - when I say mixed in one system I mean lead acid for the domestics and gel/agm for the engine start and bowthruster.)
rob
