LCD TV - Help please!
Re: freeview at northney
Aha, thanks for that. Sounds like I just need to put a bit of effort in and see if we can improve things.
Cheers,
Rick
A status 310(?) not quite certain of the model, but wd typically cost £90+ in a caravan shop.
Comes with pointy plastic antenna thing that is s'posed to catch signals that the saucer won't.
Tried it v.high up first & it was ok'ish, signal strength very high but quality lowish , esp at low spring tides; then tried it on the (steel) roof & woo hoo!, lower strength but much higher quality So borrow one if you can to make sure it'll work for you.
Also used v.low loss cable 'cos long run inside- not sure if this helped any, but it only cost a few £.
