Keith-i
I'm shortly to embark on a fairly major repair to the side decks on my Channel Island 32 due to water ingress causing saturation and localised rot in the basla core. My plan of attack is to strip off the outer skin, dry and/or replace defective areas of balsa and then lay up a new outer skin. There is no great merit in trying to salvage and refix the existing skin/deck finish as it's pretty old and rough, plus the fact that I want to renew the non-skid with Kiwi-grip anyway so the quality of surface finish and lack of gelcoat is not critical. Any exposed areas can be painted with 2-pack as a very acceptable substitute to trying to flowcoat.
I'm putting together my list of supplies that I need to order but am not quite sure what I should be aiming for with regard to cloth layers to renew the outer skin. I'm guessing something like 6 layers of 450gsm would work, but is that best as tri-axial cloth, or maybe a mix of bi-axial and woven? I'm using epoxy for the resin. Any thoughts would be welcome.
