jdc
In the UK, the air is always damp - between 70 and 90% relative humidity, on a boat surrounded by water it's going to be at the high end. That damp air finds its way into your fuel tanks as you burn fuel. Then we have a cold spell, so some of that moisture condenses - a matter of simple physics - and gets into the fuel. It's likely that most of the time, it's so little, it gets through the injectors and out through the exhaust without causing a problem. Larger amounts - you burned the fuel in the summer and left that damp air in the nearly empty tank until winter - should be caught in the filter/water trap so, again, no problem. The only time you'll have a problem from water in the fuel is because you filled up at a dubious source and bought a significant amount of water at the price of diesel.
But - there's always a but - the interface between liquid water and fuel is a place some bugs like to hang out. Get too many of them and they'll build up over time. A bumpy trip and enough space in the tank for the fuel to slosh around can cause those bugs, or their corpses, to block your filter, which can spoil your day. A biocide will prevent that if used regularly. IIRC, Premier's fuel contains a biocide.
All that applies to pre-fame diesel. I don't know enough about it to say what other problems it may cause, but a Google suggests it exacerbates the above.
It's not sure that diesel with FAME exacerbates the problem of free water, it may even help. Water does get dissolved into diesel, albeit a minuscule proportion - around 50ppm. In FAME it is a much higher proportion, around 1500ppm.
So if 7% FAME that's 0.93 * 50 + 0.07 * 1500 = 151.5. So even if only 7% FAME, about 3 x more water (from condensation or elsewhere) will simply be 'mopped up' by the diesel. To put 151.5ppm into perspective, suppose you've 30 litres in the tank: 30 * 1000 * 151.5e-6 = 4.5ml: only about a teaspoon but could be sufficient to absorb condensation. Note that this assumption that the solubility of a mixture can be estimated by linear combination of the proportions of diesel and FAME is dubious, but unlikely to make significant difference for well stored and well blended fuel).
This assumes of course that you have acquired the diesel from a good supplier who has ensured that the fuel isn't already saturated with water (by EN590 it must contain less than 200ppm out of the ~1500 it can absorb ).
A guide to handling FAME can be found here. What it says about regular addition of biocides (it says not to do it) is interesting and is exactly the same advice as IAATA guidelines for aircraft fuel.
