laying cloth on bottom of bilge keels
Rhylsailer99
19 Jun 2020
i was thinking of using duct tape to hold the cloth on both sides so it does not droop and have excess cloth with no epoxy wetting that i will sand away once it goes off.
does this sound like a good idea or a bad idea.
Masking tape up the edges of the cloth (over size) and use peel ply over the repair. Makes finishing off after loads easier. Just trim the excess cloth after.
Presumably, the keels are GRP and worn through the gelcoat on the bottom, Jissel's were like that. I just wetted out the cloth and brought it up around the sides an inch or so. Much better adhesion that way. Since I park on the mud and often dry out on sand and stuff, I put several layers and the final layer was fairly coarse stuff. 15 years later, there's no serious wear, so maybe I overdid it a bit, but I quite like stronger than necessary for things like that
If you're bothered, you could fair the edges in, but I didn't. On a serious racing yacht, it might matter, but I doubt you'd notice the difference on many boats with encapsulated bilge keels. A friend with another Snapdragon reshaped the keels to make them proper foils and swore it made a difference. Not sure a Snappy really goes fast enough for that to work, but I have wondered if winglets on the outside of the keels would help to windward. I never did it because she sits in the mud for a couple of hours every tide, so lots of stress sinking in and lifting out.
