William_H
As can be seen from above there are many ways top do a swing mooring and much depends on what you have available by way of equipment and help. The first thing to do is scrounge around for old ship anchor chain. Heavier the better. Also look out for anchors really big of any design. Or you may consider making up something like fisherman's anchors.
A mass on the bottom like a concrete block can hold the boat and may be cheap. But a devil to move into place and must be really heavy as there is not much to stop it dragging across the bottom.
A block that is small enough for you to move yourself (slung under the boat) might be useful but will need anchors on chains in various directions to hold it in place. (stop drag). jcostorfine describes how anchors can be laid with care and planning. If you can get a length like 10+ metres of heavy chain this can work well as a mass and connector between 2 anchors. Of course you can also add additional chain and anchors in additional directions to give even better holding.
The riser and buoy of course come from the middle. Chain on a mooring has a remarkably short life due to wear/rust.
Typically 8mm riser can be seriously worn in a year. The heavier the chain the longer it lasts as wear is similar. Hence find old ship chain. Heavy rope for a riser can be OK is resistant to wear but susceptible to chafe.
Once having laid the mooring you must think about maintenance and inspection. I am fortunate in being able to dive (snorkel) on mine as it is quite shallow and not cold. A deep mooring in Scotland might require expert scuba divers or a barge and winch to raise the mooring for inspection. Best is to find out how other people in your area manage their moorings.
Our local government who own the mooring areas have mandated that all moorings be professionally inspected every 2 years. A real pain. On the first inspection after I had maintained it for 28 years they reckoned the mass was unreliable. Rusted. It was a big lump of iron seemed to be in shape of a bell. I had over the years added light chain and additional anchors to the mass so it was all a bit of a mess.
They sold me a used railway wheel. About 250kg which they partially buried with a water blast from a pump. (done by a diver of course)
My riser chain is a heavy stainless steel chain (scrounged) which has lasted very well being joined by SS shackles. Beware ss on iron as the iron seems to wear /corrode even faster. good luck olewill
