Laser Flares
maxi
8 Nov 2002
Hampshire
I see PBO featuring a laser flare product, which is something that makes a lot of sense to me, BUT;
Who has ever seen one of these in action, who would recognise a laser beam as an emergency signal as opposed to a spoilt brat a few miles away playing with his dad's laser ?.
C'mon Sarah, how about an informative article generated with the flare manufacturers, plus nighttime photos?. A safety device can only work if everyone can recognise it as an emergency signal.
Twister_Ken
31 May 2001
'ang on a mo, I'll just take some bearings
Somewhere there's a bit of video from a Scottish TV programme, shot with the aid of a lifeboat crew. Conclusion, not much good. Plus, lasers are not a recognised (officially, or unofficially) method of signalling distress, so even if it's seen, the chance of it being reported as coming from someone up to their plums in foaming briny is pretty remote.
jsl
19 Dec 2001
BA2
laser beams
It seems to me that the essential requirement is a cone or finger of light which will be seen when the beam is not pointing straight at the (potential) rescuer. The voices on the video can be heard referring to a 'cone', which sounds good, but also having to direct the beam towards themselves, which sounds not-so-good. Any comments? What I'd like to have is a narrow cone which could, for example, be pointed straight upwards, waved about and perhaps flashed.
elton
19 Oct 2005
Durham, England
www.boatit.co.uk
Lasers are extremely directional and comprise of a very tight and narrow beam. They can be de-focussed to a fan shaped beam, but then would offer no advantage over a torch. The term "laser" conjures up ideas of an intensely powerful beam of light, but that isn't what they are. They are bright because they are a point source, that's all.
maxi
8 Nov 2002
Hampshire
Thanks Gents, just the sort of info that I believe is helpful to boat owners, and clearly there is some knowledge out there but on a dispersed basis.
I do believe that It would be a proactive and responsible move for PBO (or similar) to produce a summarised article so that we might be collectively informed, with data collected in an objective and balanced manner.
greenalien
11 Jun 2010
Southampton
Surprisingly, even a powerful laser beam is almost invisible when viewed from the side, unless it's scattered by smoke/fog - so the 'cone of light' pinpointing the source is a non-starter, unless accompanied by a big smoke generator. And if there's any wind at all, that smoke will disperse rapidly downwind...
ctva
8 Apr 2007
...you mean like a smoke flare??? :D
maxi77
11 Nov 2007
Kingdom of Fife
They are bright because a lot of energy is concentrated in a small beam. There is enough energy in many comercial products to cause real and permanent damage to the retina. Many lasers are powerful, they are used to cut steel slabs inches thick for example, or if you want to get realy nasty the Yanks have one in a 747 that can destroy missiles a thousand miles away.
elton
19 Oct 2005
Durham, England
www.boatit.co.uk
I believe that's what I said. But "a lot (of energy)" is relative. The narrower the beam, the greater the apparent energy.
Yes, many lasers are extremely powerful, but the ones we're discussing here are decidedly feeble.
TopDonkey
4 May 2010
portsmouth,UK
How about spinning the laser fast on a 15 degree offset ?, this would keep it pinpointed, but also create a hollow cone needed to make the laser more visible
VicS
13 Jul 2002
The one featured in post #2 looks pretty useless.
The one I like the look of and would like like to see in a comparison video is the ODEO FLARE
Not directional. In fact claimed to cover a hemisphere + 20°.
SHUG
18 Dec 2010
E Scotland
Better than Nothing I suppose.
The unidirectional properties of laser light are, in this case, a serious disadvantage.
There are alternative light sources such as small Xenon lamps or LED clusters which might be a better option.
Quote " 1 ODEO laser light equals 600 flares" where is the sense in that!!!
I presume they mean that the luminous flux in a particular direction is 600 times greater but, if that direction only encompasses one degree it is in fact much worse than a flare for SAR uses.
This is the sortof technical rubbish which clouds the issue which is.....is it generally more visible than a pyrotechnic flare?. Answer...NO. Back to the drawing board.
VicS
13 Jul 2002
No they mean it will burn for 600 times as long. 5 hours instead of 30 seconds.... Read the website!
It is not in one direction it is visible from all directions simultaneously and
projects over the the full hemisphere ... Read the website
these are the reasons that I like the idea of the Odeo. Until it is tested or gets official approval I cant say any more than I like the idea.
VicS
13 Jul 2002
Thanks for the link Vic. I would dearly like to get pyrotechnics replaced.
Do report back on what you think of it if you buy one.
Still no substitute for parachute rocket or an orange smoke though.
The only person I have ever known who was rescued as a result of using a pyrotechnic was spotted by a passing ship seeing his orange smoke.
( in the days before we all carried VHF )
