Large lithium battery as cabin baggage?
Tim Good
26 Feb 2010
Bristol
The UK aviation authority says you can't have a lithium battery above 100wh on board a plane. However there are quite a few things listed by the aviation authority which don't seem to be policed particularly.
Has anyone travelled with an electric outboard batter before and got away with it?
I'm pretty certain you wouldn't get it through.
They generally ask you to take all electrical items out of your bag before they go through the scanner. I wouldn't want to risk it.
Surely such rules are there for your safety, the safety of other passengers and crew and, ultimately, the safety of the aircraft? If anyone were to try to break such rules on any aircraft I was on, I would hope that they would be refused permission to fly and blacklisted for a substantial period of time.
Bit bothered that you ask the question. We all know you must be alright. You have a boat so must be a gentleman.
Cannot be too sure about all those types who turn right.
Would you really like the idea of being on a plane where someone has the capability to start a fire?
I suppose your right. However the instances lithium batteries have had issues is usually is when they're recharged, often phones and such like, especially when they've been flat for a long while.
Anyway as you say, rules are their for a reason.
It's not only about CAA regulations which have tight controls on lithium battery cargo. Individual airlines also have their own rules which are usually more restrictive than the regulations. Most ban lithium batteries unless they are installed in the device they are intended for.
Lithium is a particularly volatile material in battery form and I can't believe you're considering taking it without the correct permissions and paperwork in place.
If you really must try to take it, ask the airline before travelling but I suspect the answer will be no.
Lithium batteries are rightly tightly controlled across the whole aviation industry worldwide. It’s not recharging that causes the risk, it is the risk of short circuit. Lithium batteries have been thought to have been the cause of a number of fatal crashes in big (in one case a 747) aircraft. Lithium buttery fires cannot be easily extinguished either.
When you say "get away with it" do you mean didn't bring down the aircraft killing all on board?
On my recent travels with Emirates much of the information time on the screen was occupied with messages telling passengers who had dropped their mobile phones not to adjust their seats but to summon staff. Clearly, they are very concerned about the fire risk from any batteries and are not going to take any chances.
I have researched this today for a forthcoming holiday as I wanted a battery pack to power my MacBook. 160WH x 2 items per passenger is the current limit for aircraft cabins in hand baggage, you can convert this to MAH by diving by the voltage and multiplying by 1000. They are not allowed in checked baggage.
Perhaps you would like to point us to the relevant CAA reports about these fatal crashes so we can form our own opinions? - Apart from the obvious Boeing battery problems that are well known but did not cause any fatalities as far as I remember.
I fully understand why airlines have rules about lithium batteries but the rules are aimed at phone, tablet and backup batteries for those devices - such batteries are very high energy density chemistries and they have been shown to be very dangerous in certain circumstances or conditions - hence the restrictions. An outboard battery like the OP is asking about is a much safer chemistry and no where near as volatile but as far as the airlines are concerned it is still a lithium battery. Personally I would be quite happy flying on a plane with a Torquedo (or similar) battery in hold or cabin baggage - if it is not connected to anything and is properly packaged it is just as safe as some items that are allowed on board without restriction.
I am not suggesting the OP should break the rules, merely pointing out that the blanket policy of the airlines is far easier for them to police than to make exceptions for Lithium batteries that can be safely transported.
https://www.skybrary.aero/index.php/Aircraft_Fire_Risk_from_Battery-powered_Items_Carried_on_Aircraft
Some of us work in the industry and are properly informed. Others try to "get away with it".
I worked in the Oil&gas business where lithium batteries were regularly used for their high performance. All manner of dangerous goods declarations were required for ship transfers and flying was seriously restricted to freight flights in small quantities... with prior notice.
We did some discharge tests on the (D size) cells we used regularly. Dead shorts were capable of raising very high temperatures which caused chain reaction in adjacent cells. Result - quite powerful fiery explosion which as pointed out cannot be readily extinguished.
Don't even consider flying this stuff without proper preparation and documentation within regs..
Two 747s in fact, UPS in Dubai 2010 and Asiana in the Korean Straits in 2011.
That may be the CAA regulation limits for Dangerous goods by air, but is it the airline you're flying with's rules. They do differ significantly in most cases. Did you research on CAA rules or did you ask the specific airline?
You can’t ship these things by airfreight anywhere in the world in a plane with a crew of 2. I am pretty sure no airline permits them. It’s going to be even less OK in an aircraft with 300 souls.
Both - CAA & American Airlines.
I'm surprised they allow you to carry 160 wH onboard.
Normally up to 100 wH is ok.
100 - 160 needs special prior permission of the airline.
Over 160 wH needs to presented to a Dangerous goods by air carrier and packed correctly with all the correct supporting paperwork and then carried in the hold in a special storage area. Not all planes have this facility available.
As I said though, each airline may enforce its own rules as it seems fit.
Checking with your airline and getting "special permission" allows you to carry your 160wH batteries. which you seem to have done.
If the OP turns up without permission granted I'm sure he will be refused carriage.
The incidents were all overseas and happened to foreign operators so the UK CAA (or more accurately the AAIB Air Accident Investigation Branch - the CAA don’t do accident investigating) don’t have those reports. Dangerous goods regulations are set by ICAO and IATA and are enforced by national civil aviation authorities. Operators can set their own, more stringent rules. As a professional pilot, I have to undergo dangerous goods training every 24 months and have just done it. The accidents were highlighted in that training and someone has already mentioned two of them in another reply. In the past I have transported all sorts of dangerous goods, including radioactive sources and lithium batteries. Spare computer, camera and batteries for consumer goods can be carried as long as certain limits and conditions are met and these are well documented when buying tickets and at check in. The bottom line is this: if you accidentally or indeed were so minded, deliberately shorted a lithium battery big enough to power an outboard you could cause some serious damage. Sadly regulations have to be set to protect the innocent from the negligent or malicious and frustrate the honest
Have you ever tried clipping two standard (ie alkaline) PP3 batteries together? The results are interesting. Don't try it indoors. Don't hang around.
