Poignard
True.When you reassemble, only light clamping pressure is required as the taper plug will easily lock up. It can be the difference between of 1/8" turn between finger tip operation and lock up. After getting the clamping pressure correct, be careful with the lock nuts, as they may just turn the bolt a bit more and lock up the cone again. Very little pressure is needed to keep the cone from passing water.
Also, I find that problem can be avoided by putting the locknut in the position shown here:
Seacock 3/4" (blakesandtaylors.co.uk)
