Dull Spark
With winter maintenance in mind, could anyone recommend a simple and cheap method of labelling wires, pipes etc. Many thanks.
There are different types of labels - the laminated ones are said to be more stable and more appropriate for use outside.I have used the Brother P-Touch, but be aware that they are not UV stable. I tried using them outside and they faded in a matter of weeks.
+1Hmm. I use a bit of vinyl tape torn off a roll and written on with biro.
Check the model of Brother machine you buy. Some of them will print specific cable labels: name of cable, space, dashed line across tape, repeat name. You then wrap the label round the cable.....Yes one of those Brother labellers is the answer, I recall they cost less than £20. Many types of label tape available; white on black, black on white, different widths etc etc.
