Greenheart
For some reason my trapeze wires have no handles on them, just neat little crimped loops round thimbles. Nor was there any option to run a handle over the upper ends of the wires, which are likewise permanently crimped onto the mast.
So I had to fit a handle, between each wire-end and its adjustable tackle with the harness-ring on the bottom.
I chose 2.5mm Liros 'D-Pro', which seems to have a half-tonne breaking strain, but which was narrow enough to thread twice through the very narrow plastic handle...
...and I used little steel thimbles top and bottom, so there won't be undue strain on the line caused by a tight radius.
Only problem was, actually securing the D-Pro (which I think is dyneema) in a tight loop securing the handle in place.
I used a reef knot, but under great tension, I was surprised to find that the line slips, and the reef knot releases.
I hope my efforts to 'stopper' the ends by a molten heated bobble, tied tight with whipping twine, and duct-taped around, will suffice. It could all get very wet, very quickly if the trap-line lets me go when my feet are on the gunwale.
Any thoughts on whether dyneema is hard to tie? It seemed to me essentially less secure than rougher-coated line.
I guess the best solution to my problem is to have trap-wires made with handles added before the ends are crimped. But I don't fancy shelling out £40 to replace the existing ones...especially since the last owner must have managed.
