Frayed Knot
It might be best to use that posh bog sitting down for a while then...Its working..going to leave well alone.
Recently,everything I touch.................
Yes thats exactly whst it is . To check pre set preasure . Done with Jabsco pump turned off and domestic hot water de- preasured ( tap open ) . Connect pump and set to correct preasure approx 2psi below Jabsco cut inThere is on top what looks like a Schradar valve
Easier way to set the pressure without a pressure gauge or knowing what the pump pressure really is.Yes thats exactly whst it is . To check pre set preasure . Done with Jabsco pump turned off and domestic hot water de- preasured ( tap open ) . Connect pump and set to correct preasure approx 2psi below Jabsco cut in
