Kickback
andypandy1961
7 Apr 2022
2.2hp mercury marine 2 stroke.
Almost breaking my wrist with kickback on the pull start, what could be causing this and what is the fix. Just got this as a freebie and don't know anything about it.
First post so don't be too sore on me.
Thanks for any replies in advance.
Andy
Is it starting and kicking back ? Or not starting and kicking ? …I’d be checking the gearbox perhaps. These are direct drive, as you’ll know.
Sounds like the ignition is too far advanced.
That small rotation determines that kickback is caused by spark, gas ignition, and burning well before top-dead-center (BTDC) piston position. If it were after TDC (ATDC), the engine would start, idle or run normally.
pull start kick back | Boating Forum
https://forums.iboats.com › threads › pull-start-kick-bac...
21 Apr 2012 — Hi TJ, Usually the engine kicks back at starting when the ignition advance is too much for the starting speed. The ignition is advanced as you ...
Kick back when you try to start it | Boating Forum
23 May 2010
motor kick back | Boating Forum
13 Jan 2004
Recoil kick back - Iboats Forums
