Kholer 6.5efoz remote start plug
5teve
23 Feb 2016
Western Australia
Hi guys just wondering if anyone knows what connector type or manufacturer kholer use on the above model for the remote panel I have an Onan start panel and someone prior to me butchered the loom and then left the connections sitting in the bilge.. nice!
I have cut the wires back, traced and labelled them and tested the start panel tracing the schematics etc back so that remote start and stop work fine, I just do not have the plug to reconnect the harness. I suspect the original plug was cut of as it was Onan, and wouldn't fit
Any help or pointers you could give would be appreciated
edit - sorry I should say this is the plug used on the end of the wiring harness that connects into the rear of the box sat on top of the Genset.
Steve
OK found it after extensive searching through Element14
Turns out its a TE connectivity 6 way Mate n Lock universal part number 1-480704-0
well I hope it is as i've ordered a couple!
Steve
Thanks!
Well I've proved the Onan panel works with the kholer Genset (once it's working fully wired I'll there up a quick sketch of the wiring.. but it's not hard) so that in theory is the hard bit! We'll see...
Steve
