Have you inadvertently switched your wireless on (a switch on my laptop) which has picked up a wireless network at you neighbours house and is trying to log in?
Or, go to network connections and disable everything but your internet connection.
give us a clue to your puter, system, when it does this???
Try this remedy from MS. It quotes Express, but works the same for outlook
SYMPTOMS
When you run Outlook Express using Microsoft Windows 2000 or Microsoft Windows XP and connect to your Internet Service Provider (ISP) to retrieve e-mail messages from a Post Office Protocol (POP) server, your password is not retained even though you have chosen to save it.
CAUSE
The registry contains incorrect information for the Protected Storage System Provider registry subkey for your account.
RESOLUTION
To save your password you must back up your registry, remove the user account information, and then re-enter your password. Only people who are members of the Administrators group on the local computer can make these changes. Windows XP Home Edition users need to check the Users control panel. If they are not listed as an Administrator, someone with Administrator rights will have to add them to the Administrators group.
WARNING: If you use Registry Editor incorrectly, you may cause serious problems that may require you to reinstall your operating system. Microsoft cannot guarantee that you can solve problems that result from using Registry Editor incorrectly. Use Registry Editor at your own risk.
How to Back up the Registry
Windows 2000
Click Start, click Run, type regedt32 in the Open box, and then click OK.
Locate and click the following registry key:
HKEY_CURRENT_USER\Software\Microsoft\Protected Storage System Provider
On the Registry menu, click Save Key.
In the File name box, type a unique name for the key.
In the Save In box, click a location for the file, and then click Save.
On the Registry menu, click Exit.
Windows XP
On the File menu, click Export.
How to Remove the User Account Information
Windows 2000
Quit all programs.
On the Security menu, click Permissions.
Click the registry key for the user that is currently logged on and ensure that Read and Full Control are both set to Allow.
Click the Advanced button, ensure that user that is currently logged on is selected, that Full Control is listed in the Permissions column, and that This Key and Subkeys is listed in the Apply to column.
Click to select the Reset permissions on all child objects and enable propagation of inheritable permissions check box.
Click Apply, and then click Yes when you are prompted to continue.
Click OK, and then click OK.
Double-click the Protected Storage System Provider key to expand the key, click the user subkey folder that is directly below the Protected Storage System Provider key, click Delete on the Edit menu, and then click Yes in the warning message dialog box.
The user subkey folder looks similar to the following example:
S-1-5-21-124525095-708259637-1543119021-16701
NOTE: For every identity that you have, there will be a subkey under the Protected Storage System Provider key. To resolve this problem in all of your identities, you must delete all of the user subkeys folders under the Protected Storage System Provider key.
On the Registry menu, click Exit, and then restart your computer.
Windows XP
Quit all programs.
On the Edit menu, click Permissions.
Click the registry key for the user that is currently logged on and ensure that Read and Full Control permissions are both set to Allow.
Click the Advanced button, ensure that the user that is currently logged on is selected, that Full Control is listed in the Permissions column, and that This Key and Subkeys is listed in the Apply to column.
Click to select the Replace permission entries on all child objects with entries shown here that apply to child objects check box.
Click Apply, and then click Yes when you receive a prompt to continue.
Click OK, and then click OK again.
NOTE: For every identity that you have, there may be a subkey under the Protected Storage System Provider key. To resolve this issue in all of your identities, you must delete all of the user subkeys folders under the Protected Storage System Provider key.
How to Re-Enter Your Password
NOTE: These steps work for both Windows 2000 and Windows XP.
Start Outlook Express.
NOTE: If you receive a login error, close the dialog box and proceed.
Click Tools, and then click Accounts.
Click the Mail tab in the Internet Accounts window.
In the Account column, click to highlight the Internet E-mail account to be changed, and then click Properties.
On the Server tab, type your password in the Password box, and then click to select Remember password dialog box.
Click OK, and then click Close.
Close Outlook Express and then restart it.
On the Tools menu, click Send and Receive to test if your password is retained.
NOTE: If other Windows 2000 or Windows XP users are having password retention problems, re-enter the password, and then click to select the Remember Password check box for those profiles. Each user may need to log on for their password to be retained.
PS, if that doesn't work, you can also try this
To fix the problem, you need to go to the Control Panel under the Start Menu and select the one for Administrative Tools. This will give you an icon for Services. Open it and scroll down to Protected Storage. You need to set this service to start every time you boot up. So look in the pane to the left of the list of services and select Start.
Now, to order that this service be started every time you boot the computer, right-click on the Protected Storage line in the Services list and then select Properties. Change the setting to Automatic instead of Manual or Disable.
need more detailed info. Exactly which folder? are these users you've had on computer in past and no longer need. Users of what, Outlook, Operating system etc
i am the only user ( administrator ) my wife uses my settings
in the list of users in the reg key current user there is more than one entry, should there be only administrator. if more than one could it default to another for any reason ( like the problem just encountered )
OK, think I understand. No, don't delete other accounts from the registry. If you want to delete extra accounts, do it from the Control panel. Some of the entries in the registry are probably there for a reason. Some services add accounts to registry in order to run
