Oaks81
When storing a boat it is generally recommended to support the weight of the boat with blocks under the keel. However, my stands only have "pads" on the sides. The manufacturer of the stands claimed that the stands are sufficient for my boat size (about 900 kg). What's your opinion? Do I need keel support in the middle? If it is necessary, the easiest solution might be to replace the front one with a stand that supports the keel.
The instruction book of the boat only states that it must be supported in a way that the weight of the boat does not damage it.
