Clyde_Wanderer
I have removed all the keel stud nuts and washers on the inside of the hull.
Under the washers were a hard wood backing about 50x80mm and aprox 15mm thick, the studs, nuts, and washers are steel. What I was wanting to know is can I replace the hard wood backers with, say, galvenized steel 12mm thick? As I feel that over time the hard wood backers will compress and yeild to the compression of the stud nuts, allowing the effect of the tightness of the nuts to deminish, whereas steel plates shouldent yeald.
Would like to hear the forum's opinion on this.
Thanks.
Thanks.
