Plevier
Looks just like my SO32 (lift keel version) as well. I think these Jeanneaus are quite flexible.
Incidentally my keel bolts are plain steel not stainless.
Hi,
She's been inspected (Owen Catchpole) and scraped, and she is fine. It's just a filler issue. I'm doing the update as a thank you to everyone that offered help but also in case someone in future searches on:
Sun Odyssey 35 Keel Hull Joint
Person from the future this is for you - if your cracks look like ours - there's not much to worry about!
Thanks for the advice everyone.
I have the same boat, fin keel Jeanneau SO35. The keel is cast iron, coated externally from new with a thin layer of polyester filler-type material to try and cut down rusting.Hi,
With the boat out of the water I took the opportunity today to have a good poke around underneath her. I noticed that the joint between the keel and the hull has opened slightly - or more likely, that the filler material has cracked and fallen out.
The discolouration of the hull suggest to me that there is some water ingress which is gradually leaking back out - thought the freezing weather seems to have put a stop to it. Am I right about that?
I will be getting it looked at next month - but in the meantime - should I be worrying about this? Am I looking at a major repair or is it something more pedestrian?
She's a S/O 35 if it makes any difference.
Thanks for any input.
